Troubleshooting large format printing problems
Graphic Arts
19 Dec 2022
The smallest issue can ruin an entire print job, making it critical to ensure your large format printing systems work the way they should and that you adhere to all best practices. You might wonder precisely what common problems affect large format printers and how you can resolve them. Here, we'll explore these issues and the appropriate solutions to them.
You're likely to spend a lot of time and money on large format printing, and seemingly minor issues like clogged printheads can ruin large sheets of paper—many of them if you're not paying attention. You never want to find yourself in this position, so what can you do to prevent it? Let's take a closer look.
Some Common Large Format Printing Pitfalls
Large format printers may experience certain types of printing problems that are important to address and resolve. A few of the most common issues you might see with large format digital printing include the following:
The Wrong Colours
Using RGB in Lieu of CMYK
Low-Resolution Images
What Are Some Solutions to Common Problems With Printers?
AEC project manager analyzing blueprints with common large format printing errors
Once you set up your new printer, there are some common printer problems you may experience over time or even when you start using it for the first time. The following are some solutions you can implement to resolve various printer problems:
Check Various Parts of the Printer If Your Prints Aren’t Coming Out Despite Having Ink
Set Your Printer to the Right Resolution
Take the Right Steps to Unclog Your Printhead
Consider Managed Print Services
What Are Printer Maintenance Techniques?
Whether you’re using a conventional printer, a thermal printer, an ID card printer, or another type of large format printer, preventative maintenance will help avoid potential issues. To improve print quality and keep your printer in great condition, here are some large format printing tips to follow:
Invest in a Printer Maintenance Kit
Align and Clean the Printheads
Clean the Inside of the Printer
Clean the Feeder Rollers
Reach Out to HP to Meet Your Printing Needs
Looking for the right printing solution to meet your projects' requirements? HP is here with some of the best supplies available. Contact us today to discuss your printing needs.
Download our eBook now and discover how innovation is streamlining workflows, producing prints of unmatched quality and increasing IT efficiency like never before.
Download eBook now
